Help fixing 289-760-999 CIFIAL Diverter
CABrouwers
Oct 6, 2020
7
USA
I have a Cifial 289-760-999 diverter that is no longer working. I removed the trim and opened it up, expecting to find a replaceable cartridge, but I’m not sure if there is one. If there is a cartridge, I don’t see how to remove it.
If there isn't a replaceable cartridge, I’d like to know how to fix the diverter without having to break tiles and open the wall.
I've attached a cut-sheet for the part and a picture of the installed unit. Any guidance would be greatly appreciated!
The rest of it pulls straight out. The bonnet nut that holds the stem in the valve you have already removed.
Thanks, it works. I was afraid to break something.
Celebration GIF by LaGuardia-Wagner Archives
I have one more issue to solve. The water leaks around the diverter o-ring, which is brand new; and then comes out through the stem. Any suggestion?
You’ll need to try to replace that oring OR call whoever you bought the part from and ask for a entirely new stem
