Well, I went in & hit a snag- the shutoff is leaking. I managed to cut stuff apart & start assembling and realized my dumb a$$ should have measured first because the hose is too long but I need it to get the right angle. I thought about getting a longer metal pipe at the inlet side, but I was barely able to turn it bc of the route of the outlet side. It got really hot & wasps were buzzing around. Heat made my brain shut down so I'm cooling off & coming up with a plan. I'm going to skip some of the parts & see if I can get it to go together. I wish I had more space to work with. If the pipe was all the same size it wouldn't be a problem, but I have to convert from 3/4" up to 1-1/4" and they didn't sell a single fitting to accomplish that so I need at least two to get there. I can stick a 3/4" coupling inside the 1-1/4" to 1" elbow. I wish I had just a straight piece. Worst case I could always go to the hardware store & get one.
I'm about to go out there & try the parts. Wish the damn wasps weren't around ,but I don't want to spray poison near the water well. One of my cats was in there with me watching me work. She got up on the pressure tank at one point and put her paws on my chest and wanted to be cuddled. Then she sat on the ground & started swatting wasps that came near her. One of the buggers landed on my sleeve for awhile. I kept saying "I'm not going near your nests, leave me the f*** alone!"
Edit: I think I've figured out a solution but I can't cut before the shutoff until the water level in the holding tank goes down more. I opened the shutoff up & it was pouring water out & flooding the pump house, so for now I have it closed & normally the water level in the holding tank goes down when the pumps are off. Now, I don't know if the water drains into the lines via gravity, or if it just goes back down from where it came. But, I'm going to have to wait & see. The entire thing did drain in the past when there was a leak. I might just call my well guy & ask him about coming out with the right fittings to convert it over to 1-1/4".
