Ran into a problem replacing my toilet. Previous owner installed an extender on the flange as the flange is about an inch below the floor. However, I cannot remove the bolts as it appears as though the extender was installed over the bolts so the keyhole is partially covered by the extender. Unfortunately, the current bolts are too short to use for the new toilet. Any ideas on how to remove the bolts? They're loose and I was able to pull of a washer from one of them using pliers but there does not seem to be enough space to pull out the bolts. I guess right now I prefer to not cut the extender but if I have to, what would be the best method to cut out the bolts? Seems like a worse problem is putting new bolts in if I cut the current bolts to make it easier to remove. Attached a photo.
