BevP
Hi, my name is Bev, and I just joined this forum since you seem like a group who could help with these questions. So thanks in advance! A drip irrigation system was just installed on my property, and there are a few issues with it, such as all the trees on the drain field being uprooted rather than cut at the base as was specified in the engineering plan. I understand the purpose of that was to have helped with soil stabilization. But there are two issues I would like to know more about :
- The drain field covering was specified on the engineering plan as 12" of topsoil, with no aggregate larger than 3/4." But apparently there was some free fill dirt available, because the field is now covered with dirt containing rocks larger than 3/4" in almost every square inch, and in some cases actual boulders. My questions are:
- Will that affect the functioning of the system, and if so how?
- Should I be concerned that the boulders have damaged the lines? They were rolled over the connectors that were projecting above the trenches. The system is functioning now, but there is only one person currently using a field that is designed for four bedrooms in case of future additions.
- Even if damage is not obvious now, should I be confident that the drain field won't be compromised over time?
- Is it okay that the drip lines that were buried in 6" trenches are embedded with shards of shale?
- In one place where the excavator encountered rock, the force main was only buried to half the specified depth of 36," which places it above the frost line. Questions:
- If it has to be rerouted, is it okay if the pipes are run near a well? I know there are usually 50' restrictions for the tanks and the drain field, but can't find anything about the lines.
- Similar to the drip lines, these pipes were embedded in and covered with shards of shale, but even larger and more extreme. The pipes are schedule 40 PVC, so I assume they are tougher than the drip lines. But is that okay?
