RapaNui
Hi all,
This past Summer we purchased our first house, a split-level from the 1960's. With this purchase we had the sewer line inspected by camera and cleaned a couple months after we moved in. Since we've had the house, the basement toilet splashes when upstairs toilet is flushed. These toilets are more or less stacked on top of one another, with the vent pipe directly above the upstairs bathroom on the roof (one vent pipe in the house).
Recently we've been experiencing overflows from a nearby drain in the basement when we run a load of laundry through the washer. The overflow is the worst on the first washer empty. This drain is between the utility sink the washer empties into and the main sewer line out of the house. The largest overflow of the drain was from a single upstairs toilet flush after returning from 3 days of being away from the house; however, flushing the upstairs toilet doesn't usually cause an overflow. The basement toilet also bubbles sometimes when the upstairs shower is running, along with the sound of running water in the utility sink drain (likely vacated p-trap), and a slight overflow of the basement drain. This is infrequent, but does happen.
Attempted solutions. I ran a 15ft auger through basement plumbing lines, but couldn't get into the drain, so I called a professional. The plumber was able to snake between the drain that overflows and the main sewer line out of the house. So, everything should be clean in the pipes between the overflowing drain and where it exits the house. Since this didn't fix the problem, I did what he next recommended, installed a studor vent behind the utility sink. Still didn't help. Two days ago, I purchased a 50ft auger and ran it into the main vent on the roof, but it didn't hit anything. I flushed the vent with the hose, but the basement toilet is still splashing.
What's next? Are these multiple different problems? Is it just bad plumbing in the house? Or is there a clog somewhere?
Thanks so much!
Thanks so much!
