RickFlorida
Hi everyone,
I'm about to finalize the design of my irrigation system. There's something I'm not sure about. The old system I removed was an indexing valve type system. I have moved the pump location and will be using 3 solenoid valves (for 3 zones). I have an artesian well (constant pressure).
I know I need a filter on the 2 inch inlet PVC before it enters pumps, but what I'm not sure of is do I need any kind of check valve or one way valve? What I don't understand is how come when the pump was off when it had the old indexing valve, why didn't the constant pressure of the well push water through the zones when pump was off? Will my new solenoid valves automatically go in the closed position when off so that will also stop the constant pressure of water going through the zones when pump is off? I read that only irrigation pumps that are on city water will use a master solenoid valve before the zone valves. So I think I only need 3 valves for the 3 zones. But is that what will stop water from contantly flowing from my artesian well when the pump is off?
thanks,
thanks,
