Hi,
I have a deep-well jet pump that will not build pressure.
The symptoms are as follows: when the pump runs, it has about 40 PSI, and I can get water to my faucets. But when I turn off the pump using the switch, the pressure bleeds off quickly down to around 20 PSI and doesn't hold.
What I did to diagnose the problem: First, I checked to see if it lost its prime, but water was being held in the suction pipe. Then, I drained the tank and checked the air pressure holding at 38 PSI. Next, I swapped the pressure switch out for a known good switch, thinking maybe a bad switch, but the same results. I then turned off the supply valve to the tank with the pump running, and it was the same as when the valve opened about 40 PSI. When I turn off the pump, the pressure holds between 10 to 20 PSI and slowly bleeds off over about an hour.
P.S. We replaced the whole system about five years ago, pulling the plumbing out of the ground, replacing the pipes and foot valve, and putting in a new deep jet pump and (Bladder) pressure tank.
