The back pressure is always less than most people would think. A 10 GPM, 1/2HP pump can only make about 100 PSI max. You can scale up the HP and flow without increasing back pressure. A 20 GPM, 1HP or a 40 GPM 2HP will also only make about 100 PSI max. It is the small volume, high horsepower pumps that build the most back pressure. A 10 PM, 1HP can build almost 200 PSI. But a pump like that should be installed in a well where the water level is at least 150'-200' deep, which will eat up a 100 PSI of the 200 that pump can build. Which means you still only see about 100 PSI back pressure before the CSV. Only pumps that are way over sized, like when made for a 500' deep well and the water level is only 100' does back pressure become an issue. But no matter how much back pressure it makes, each pump was designed to make that much. So, as you said, the only issue, even with way oversized pumps, is to make sure the pipe before the CSV is rated for enough pressure. After the CSV, any pipe will work as it will only see 40 to 60 PSI max.
