Cutting hole in sump pit
Kg5544
Nov 28, 2021
Illinois
I need to cut a new 4 3/4” hole in my sump pit to add a drain line for a toilet. Would a hole saw accomplish this? What is the best way to go about doing this? I believe the pit is fiberglass.
Whoa, toilet dump into your sump. Something isn't right there. Is it a sewage ejector sealed pit
O.P., a sewage ejector system for plumbing is not called a sump pit.
A sump pit typically refers to ground water only.
Also, bathrooms with toilets only need 3" pipe size, not 4"
