I thought this would be easy, but its presenting some challenges...
My house came with a home propane tank and a quick connect fitting on the deck, presumably for hooking up a grill.
I have a wok burner that i would like to plug into that fitting.
The Wok burner has what I believe to be a 1/8" MNPT fitting with a tiny hole in it that goes to a 10psi regulator, and then has a big plastic knob-like screw on connector for a propane tank. How do I adapt this to a quick connect system, and do I need the regulator?
I bought a hose that I thought would work, but the end that would screw into the Wok is too big and doesn't have a reducer on it (a piece of brass that reduces the ID to almost pinhole size).
