thetoolsmith
I'm trying to plan out my new plumbing to connect a wall hung toilet to and existing 2" drain and vent. In the image below the new wall hung toilet is covered in black plastic to help keep things clean. The old 3 inch drain is in the left bay and turns vertical down through a 2x4 supporting wall near the new toilet. This old 3" plumbing can be removed (hopefully)
I've sketched out what I hope will work using a 3x3x3x2 Hub Sanitary Tee with 90 Left Inlet to connect the revamped 2" drain/vent to the new 3" drain. I'm assuming I can cap the top 3" opening if this setup works. Does this setup look like it will work?
Thanks for any feedback
