Kirk Burress
I am not a plumber but I volunteered to replace a single basin wash tub with a 3-basin commercial sink in an old grocery store turned non-profit soup kitchen. I used standard residential plumbing fittings and it worked fine but not for long. About every 3 months the pipes have loosened to the point they start to leak and actually all start falling apart. This includes not only the plastic fittings but tonight the metal collar holding the rubber drain gasket was only finger tight yet I tightened it with a wrench when I installed it. These basins get banged when cleaning big pots and they are subjected to temperature extremes when boiling water is added to augment our inadequate water heater. What can I do to keep the plumbing intact? Thank you
