Daphne Crook
I recently replaced my water heater and also the hoses that connect to the pipes in the wall. I did have to reem on the wall pipes pretty good, but do not feel I broke or bent then in any way. However, with everything connected and ready to go, I turn on the cold water valve, and it flows for about half a second only. I removed the hose from the water heater end, and turned it on, the flow was a dribble at best. We turned on other faucets in the house and all cold water works. Hot water doesn't, but that's expected since the hot water isn't fully hooked up yet. We've searched the wall and ground for leaks... Nothing. We've troubleshooted a ton! We thought an airlock, but all our faucets are mixed taps and have the "no return" taps, so we can't use normal methods to test for an airlock. After all our testing and trial, a few hours later, we tried the cold water faucets in the house again. Outside hoses work, downstairs cold water works, upstairs cold water does not. And still no change to the cold water valve for our water heater pipe.
Please help!!!
Please help!!!
