I have sink drain that is a copper pipe leading to a cast iron stack. The copper pipe is leaking about half an inch before it goes into the stack. I need to change the copper pipe. There appears to be a pipe connector screwed into the side of the stack however I CANNOT unscrew it for the life of me. I've tried soaking it with WD40 and letting that sit. I've banged on it with a hammer (might have been a little more gentle here than necessary as I didn't want to crack the stack). I've tried heating it with a MAP gas torch. It will not budge. How do I twist this thing out? Is that even the best thing to do?
