Don't hit it with a hammer you could crack the cast iron. (big no no) Cut the copper pipe off as close to the fitting in the cast iron as possible. Using a hacksaw blade make two cuts on the inside of brass fitting a 1/2" apart. Being careful not to cut into the threads in the cast iron fitting. (take your time) After you have made the two cuts pick out the small section of brass. (it must be removed the entire length of the fitting) Then using channel lock pliers collapse the fitting by squeezing it. At that point it will turnout very easy.
John
I have a thread with picture some where floating around on this forum. I'll go find it.
Found it. Wasn't one I started so it was a little harder to find.
clogged-bathroom-sink-pipes-broken-nipple-threads-1383/
