Bucky Plumber
Was wondering if it is possible to change the angle of rotation for a disc kitchen faucet.
When you turn the handle to hot it can bump against the window trim behind the faucet. Ideally I would like to make hot straight up, flush with the faucet spout.
I dis-assembled the faucet pictured below and the valve cartridge only fits as it was originally built. The brass piece that controls mixture of the warm and cold water is continuous with the mounting bracket, therefore unable to angle it.
Is there some way to adjust this angle or are there faucets that do not rotate past the faucet spout?
Thanks in advance!
Thanks in advance!
