HereComesJoe
Hello all!
I’d greatly appreciate any help and advice from this forum.
The problem occurred after a routine router rooter clean out. Every couple years my basement will back up and due to roots and such clogging the pipe. This is usually remedied quickly with a snake. The clean out is usually done in the basement but can sometimes be done from the street.
After my most recent clean out I have experienced strong sewer smells. I noticed that the sewer trap no longer holds water. For reference, The top of the trap just sticks out from the floor and the rest is in the concrete.
In an attempt to eliminate the smell the plumbers cemented pvc on top of both the trap and an access that is further on down into the house. They then installed screw on caps.
The smell is still strong and when the heat kicks on it comes up through the vents.
The plumbers have been back and suggested running all the plumbing overhead. Thus eliminating everything in the floor. This causes a problem however Bc my basement relies on a trough drainage system with no sump pump. Eliminating the floor drainage would cause heavy backups with no source for water removal.
My question is, if there is a smell coming up from the the broken trap, would a pvc cap be enough to stop it from escaping?
Could the problem be solved by replacing the trap?
If not how might I figure out where this smell is escaping?
Thanks to everyone in advanced!
Joe
Joe
