Broken galvanized T
Wolfman420
Feb 26, 2025
Iowa City, Iowa
I have a 1974 mobile home. Last winter the furnace went out & the pipes froze. They are galvanized & a T broke. I had a plumber look @ it & he said it could not be repaired without replacing all the pipes in the home with pex. Said the vibration would cause it to crack elsewhere. My thought was cut & thread 2 of the 3 pipes then unscrew the T & replace it & install unions on the cut 2. Living on SS & having just replace my futnace I need the cheap way out.
They are upselling you. I have cut and replaced numerous galvanized pipes, with the caviot that the homeowner understands that the pipe SHOULD be replaced soon.
Get another bid and only ask for what it needed to get you up and running.
lastly, you should always get a minimum of 3 bids for any work needed.
Galvanized fittings can be brazed or silver soldered, but the galvanization must be ground off first…and of course, be fire aware!!
Yah I kinda thought so. They also told me my little tankless water heater was illegal & they would also have to replace it with a regular one before they could repair the pipes.
If you have galvanized water pipes then I also recommend a complete repipe. I don’t blame the plumber for not wanting that nightmare…..you should thank that plumber for good advice even if you don’t accept it.
Wull decided to drag my 67 year old ass under there. Ain't no welding this one. Going to be a bitch to thread them (tight corners) but gotta try cant hurt anything. Have a brass T & 2 unions coming .20250226_161221.jpg
Yah I kinda thought so. They also told me my little tankless water heater was illegal & they would also have to replace it with a regular one before they could repair the pipes. gonna do it myself
It might be illegal. Plumbers have to play by different rules than the unlicensed and homeowners. Post pics and let’s see the heater
There are various gas devices including water heaters that are certified for use in a mobile home, and those that are not. I cannot speak to the price difference between them, but common sense says you use the right water heater in the right application.
Wull decided to drag my 67 year old ass under there. Ain't no welding this one. Going to be a bitch to thread them (tight corners) but gotta try cant hurt anything. Have a brass T & 2 unions coming .View attachment 48192
Yeah, that’s for sure! I thought it was a recent split, not a blowout! Apparently it has been leaking for a few minutes.
You’d be lucky to get three plumbers to even call you back much less get three bids.
Most companies will not give you a price on the phone and no one’s coming out to look at repairing 1974 mobile homes GALVANIZED water pipe. I almost laughed typing that out but I’m trying to be good…..it’s Sunday 😑
When has the day of the week stopped you from being the snarky Two Whack we all know? :lightening:
All you’re doing is trying to hurt my feelings but little do you know I don’t have feelings except for when I get that gas at the dentist office. That’s when I do my best posting on here is when I’m at the dentist.
Fake feelings is all I got left boss hog
