jcrisp6
I'm in the middle of replacing a faucet kit that my friend bought for her very old home. I want to replace the sink drain that came with the new Moen faucet kit. After some turning and twisting, I have loosened the old one but still can't disconnect it. I have loosened the seal which you see hanging around the pipe in the picture below. I'm having trouble finding the circled piece that goes around the drain where the over flow drain tubing connects. I have no clue what this piece is actually called and I've searched the web for every combination of terms I could think of that it might be called. Is such a replacement part still available anymore or will I have to retrofit it to work with newer style plumbing? Any info would be greatly appreciated.
