yargnawh
Hi Everyone,
First I want to thank anyone who's taking the time to read this and offer their advice. I'm an over-confident DIYer, probably biting off more than I can chew, but for something like this I want to make sure I'm doing it right. Secondly, want to apologize if any of my plans appears poorly drawn, stupid or ignorant. I feel like I've done ample research, but a few days of Googling and Youtubing is nothing compared to years of experience.
So the plan is to build a bathroom with shower in my basement. I never used a 3d modeling software until I wrote this post, so the pipe fittings ARE NOT ACCURATE in drawing. Assume the pipes are sloped properly (1/4" per foot for waste and vents). Stud placement is not to scale
This is the top view:
A few things to note:
- I'm located in NJ.
- The bathroom is 5' wide and roughly 13' in length.
- Due to the location of existing lally columns, ducts, stairs, and other "un-movables", this is the best use of space.
- The sewage pit placement can be moved maybe a few inches.
- The toilet wall is framed with 2"x6"
This is a side-ish view:
Back View:
Rendered View:
Additional Questions:
Again, thanks again for reading and advising.
Back View:
Rendered View:
- Venting:
* True/false, AAV can be used for the ejector? (https://ipsplumbingproducts.com/wp-content/uploads/2020/07/Studor-Sump-Pump_071420.pdf)
* True/false, AAV can be used for the sink + toilet + shower?-
* True/false, the sewage pit vent CANNOT be combined with the sink + toilet + shower vent?
* If it cannot be combined and no AAV, does that mean I need to run TWO 2" pipes from the basement ALL THE WAY to the roof?!
* Can I use a wye for the vent fitting off of the waste pipe? Can't find an exact answer for horizontal venting...
- Main Line:
* For the ejector discharge, starting from the bottom:
- 2" pipe ==>
- check value ==>
- on/off valve ==>
- 90 deg elbow to horizontal, higher than the main line (regular or long sweep?) ==>
- 90 deg elbow to vertical in to ==>
- 4" x 2" x 4" wye (spliced in the main line using 2 x 4" No Hub Coupling)
- Ejector:
* True/false, should be on separate GFCI breaker?
