I have started basement kitchen project. Per main designer/architect (my wife) request is to install kitchen sink at about 112" away from sewer main drain line on the left side of the picture.
I need 1/4" of slope per 1 foot; since I am at about 9 1/2 feet away - I need it to be at around 2 1/2 drop. There are couple of concerns:
1. Longer wall (left side) is the outside underground concrete wall (there is a window in the middle). There is 4" between the inner stud and concrete. Winters can be cold, but basement is heated - do I need to add additional insulation around pipes? This is not a load bearing wall.
2. Starting with 17 1/2" off the floor to middle of 2" pipe (34 1/2" counter high - 8" deep sink - 7" disposal) - 10ft long pipe - 2 1/2" drop - leaves about 2" to connect to 3" house main drain as clean out fitting is at 12" off the ground. What low clearance fittings/options are available to connect 2" to 3" pipe? I am not sure about durability of rubber couplers as you can see in one of the pictures - this same main drain is connected to 2 bathrooms + 3 sinks from above; any leak can be 'messy'.
3. Do I must ditch the disposal - that would give another 7" to work with - I could then raise the drain to almost 22" off the floor.
4. Would it make a difference going to 1 1/2" pipe - plan is to have kitchen sink with disposal, dishwasher and RO system for drinking water and fridge.
5. Does this additional sink connection require an air vent; or a p-trap is what all it takes?
6. I know it would be easier to move the sink closer to clean out; but wife wants to have kitchen sink below the window.
Looking for an advise and recommendations; thank you very much in advance.
