I have a long-time issue with my kitchen sink. Double sink with both drains going into one trap and one drain for both disposal and sink.
It is a slow drain. It has totally clogged before requiring a snake to clear. If disposal side is run too long it fills with water which shoots into the other drain if the disposal is turned on. Both sides eventually drain. Water also backs up into dishwasher line creating stagnant water. Drain is and always has been slow. I brought a plumber out yesterday that thinks this is a venting issue and not a clog. But he does not do venting nor does he know anyone that does. The kitchen sink and a small bar sink (below it on the same side of the house) are slow. The bar sink is slow until it gets going then it seems ok. A bathroom directly above the kitchen sink all drains work as normal. My attic has several vents all tied into one (see pic). These are not all of the vents in the attic.
In the video, I put the sink plug in, filled it, then removed the plug. This access hole is a vent that I installed which does nothing to help the issue. You can see that air comes out of the hole when the sink is draining. You can hear the gurgling when it is done. If I don't put the plastic on it, water pours out of this hole.
Does anyone know what this problem actually is and how to fix it?
