corrosive, mineral fall out and scalds.I thought you were just talking about water that hot being dangerous.
Yeah, I'm pretty clear on that. But again, Honeywell-Residio is really touting "anti scald" and they suggest nursing homes as an application. I gotta think they're pretty confident in the technology to be saying that. I'm gonna research it more, but open to turning the water heater no higher than 140, which still gives roughly 1/3 more hot water, than set at 120.He is ,he wants you to know how quickly water scalds
The Honeywell-Residio one I'm using (and linked above) claims to be "thermostatic". Is this wrong ?Nursing homes are also required to have thermostatic shower valves, something you don’t have most likely. It’s a step up from pressure balanced with hot water limiter.
He was and it is. Listen to the experts.I though @Twowaxhat was saying fouling with minerals is more likely at higher temps.
Nursing homes have thermostatic mixing valves at the individual showers also.The Honeywell-Residio one I'm using (and linked above) claims to be "thermostatic". Is this wrong ?
you need an expansion tank due to the check valve .Are you not getting enough hot water why do you think you need an expansion tank????
I'm not one of the experts on this issue, but one fact is that 125-degree water can cause immediate burns to a person. So, a 160-degree setting would be extremely dangerous if you are relying on a single device that may fail and allow that high temperature water to flow to a fixture. Another fact is that the higher the temperature the water is heated, the fall out of any minerals (aka scaling) increases significantly.Ok, I'll listen to the experts ... what do you think I should to do ? Ditch this idea altogether (in which case, who IS a good candidate for such a mixing valve) ? Don't turn the water heater above 140, and live with only an approximate 33% increase in available hot water ?
Ok, I think the answer is to turn the water heater up no higher than 140 degrees until I can confirm (or upgrade) all the shower valves to be of the anti-scald type; it looks like that's fairly standard with new ones these days, but I think the ones in this house date from its construction 20 years ago, so likely would need to be upgraded.You asked, "who IS a good candidate for such a mixing valve". Limiting the inlet temperature of the hot water to 140-degrees would be less risk.
And as Twowaxhack says above, who is an expert, "Nursing homes have thermostatic mixing valves at the individual showers also.
RustyShackleford said he has purchased a mixing valve and was going to turn up his water heater to 160 and use the mixing valve to control the water to 120 going to his fixtures. So, I'm assuming he is still going to install that mixing valve when he increases the water heater temperature to 140 and limit the water to his fixtures to 120.Whoa.
Hot water at a FAUCET (be it a shower or lavatory or kitchen faucet; point of use where hands get in) really should NOT be more than 120 or 125 degrees. Beyond that you run the risk of scalding and even 3rd degree burns in children or elderly. You indicated "renters", and if you had your water set to 140 degrees, which is higher than expected in any normal condition, you are setting yourself up for a potential liability, and causing permanent damage accidentally to your renters.
If anyone other than your own immediate family is using your home, you need to do whatever it takes at each point of use (washing machines and dishwashers aside) to limit the hot water to that 120 degrees or so. Whether you do it with anti-scald valves, mixing valves, tempering valves or whatever, you really ought to consider it for safety's sake.
It may be just easier to get that tankless since you said you do exhaust the water in a 50 gallon tank style.
I'm a home inspector, and if I found 140 degree water at a faucet that would be a huge red flag.
FWIW I had showers built in 1990 and 1992, and both had anti-scald valves, pressure balanced.
Correct. Install mixing valve, turn water heater up to 140, set mixing valve to output water to 120 (or perhaps slightly lower, whatever the hottest shower a person could possibly desire is).RustyShackleford said he has purchased a mixing valve and was going to turn up his water heater to 160 and use the mixing valve to control the water to 120 going to his fixtures. So, I'm assuming he is still going to install that mixing valve when he increases the water heater temperature to 140 and limit the water to his fixtures to 120.
A big part of my rationale is that there are 3 bathrooms. So that'd be one honking tankless. Also, there's no natural gas, just propane, so pretty expensive (of course electric is a non-starter for one this powerful).I'm sure you have replaced your water heater in the 20 years of the house, and probably more than once. Depending on the age of the one you have now, you may want to go ahead and replace it with a tankless water heater and use that technology which would resolve your issue without multiple devices.
I really would like to stay away from propane - not only is it more expensive per unit of energy, they are necessarily less efficient due to the need for a flue of some kind.You can buy 75 gallon gas water heaters at Lowes or Home Depot. They start at about $1600 and go up past $2000.. they are gas burners are 76,000 BTU hours, which is close to twice the size of most of their water heaters in the 50 gallon size. While Lowe’s does not list it with propane, it is available...
