RustyShackleford
I want to add to my water heater an expansion tank (house has closed plumbing system) and a mixing (aka. tempering) valve, so that the temperature can be set at 160-degrees or so for add'l hot water capacity.
The water heater is in the basement, and currently both the cold and hot connections are soldered 3/4" rigid copper pipe going straight up from the tank connections into the two living floors of the house (with a shutoff valve on the cold inlet pipe).
I'm thinking of adding the expansion tank and mixing valve as shown here.
The black squiggly thing is a flexible water-heater connector.
Wondering about the positioning of the two devices.
1. Is it ok for the expansion tank to be on its side (as shown) and is it ok for it to be completely above the water heater ? Searching, it's often shown hanging off the side of the cold-water line, so the opening is pointed upwards and the whole thing is below the top of the water heater.
I'm guessing this drawing (from the install instructions) says it's ok. It shows the tank optionally both sideways and completely above the water heater (though not both at the same time).
2. Is it ok for the mixing valve to be oriented as shown (with the outlet pointed upwards) ? The instruction sheet for the one I've purchased (https://digitalassets.resideo.com/damroot/Original/10014/62-3075EFS.pdf) is really confusing. The paragraph on the lower-right of the first page says "can be installed in any position consistent with the intended use" but then "for domestic hot water supply, the valve must be installed as shown in Fig. 1" and Fig.1 shows the thing oriented wit the outlet pointing sideways and the hot and cold coming in from the bottom and top (it's also showing a recirculation system, which I don't have).
I guess the reason my positioning of the components is so different from the various instructions is that I have the cold and hot lines coming in from directly above the water heater.
