hoosiermd
Let me start by saying hello, and thank you in advance for all who read and attempt to offer advice.
We have a Richmond 18kW electric tankless. It is only around 18 months old, and it's been around 12 months since I last successfully flushed it. Now, it won't even flush. When running, the water begins heating, then it goes cold BUT the unit stays on...it then gets hot again...then cold, confirmed by holding the copper hot water exit line. It oscillates like thus until it throws an error (E4) which I believe is an overheat error. More oddly, the longer the water has been on (and before it errors), water flow at the fixture slows to a trickle. If power to the hot water heater is turned off (so only cold water flows through), it never slows to a trickle.
I purchased Rectorseal Calci Free (sulfamic acid) and attempted to flush it, but the same issue occurs. The flow starts high but then slows to a trickle. I disconnected the pump and tested it alone in a loop and got good flow. I reconnected the pump using the same hoses to the water heater using cold tap water instead of the acid solution, and it flowed through the water heater fairly well, for several minutes. I immediately put it back into the acid solution and within 30 seconds it slowed down to a trickle. I then put ice into the acid solution (where I know it works better warm but I wanted to take the temperature variable out), and it still slowed to a trickle. The filter screen on the cold in is clean.
Absolutely any advice is welcomed.
