thetoolsmith
I'm installing a Toto wall hung toilet as part of our bathroom renovation and wanted to get some feedback on putting a 3" ABS pipe through an adjacent 2x10 floor joist that sits on a wall partition below. Hopefully with my sketch and photos I can relay what I'd like to do. The current 3" pipe runs horizontally from the old toilet and then turns 90 degrees vertically down the wall. The drain pipe on the right will be removed (it's from the old shower) The pipe which runs perpendicular to the right is tied to the vent so that'll stay.
Our new Toto wall carrier is under the black plastic to help keep it clean while we renovate. Ideally I would like to replace the 90 that turns down the wall and use a combination long radius tee-wye and drill a 4" hole through the 2x10 to reach the new toilet. I know this violates the 1/3 rule but I'll be able to keep at least 2" on both the top and bottom of the 2x10 which is supported directly below by the wall downstairs.
Does this seem feasible or is this just a bad idea altogether?
Any tips or feedback would be greatly appreciated.
Thanks!
Thanks!
