Non-professional (and first-time poster) looking for experienced opinions on a recent plumbing failure. The attached jpg file shows a picture of a failed water supply line for a bathroom faucet. Im trying to determine if the failure was due to age, poor material, or some outside influence like mice, etc.
The failed supply line came as part of a vessel sink faucet that was installed about 10 years ago. Not sure of manufacturer but it was purchased on belacor.com and might have been Danze. No problems with the faucet or supply lines until just recently, when the line suddenly burst open and started spraying water. Fortunately I was 8 ft away and able to shut it off fairly quickly.
After cleanup I started taking the faucet off because I couldnt get the supply lines off with the faucet installed. As I did that, the other (hot) supply line then burst open as well! Both lines showed the same unraveled steel mesh around the blowout site. Seems highly coincidental that they both failed within minutes of each other. The sections that failed may have been slightly kinked. Also, the bathroom where this occurred is right next to my garage, where Ive found mice before. However there are no signs of mouse droppings under the vanity and I dont see any entry points. For what its worth, right before the blowout happened my dishwasher had switched off its rinse cycle, so there was probably a temporary surge in water pressure.
Any thoughts on what happened here? Thanks in advance for your thoughts, while Im waiting for responses Ill be washing the 37 towels I used to clean up the mess.
