Starcraft27
Hi. my 3/4" copper main to my house was hit with a shovel and damaged badly where its restricting water. About a foot of the line needs to be replaced. Is the best way to replace to cut out as close of a peice of new 3/4" line and two repair unions to slide over on each side and solder?
Also my main shut off valve does not shut off all the way I wanted to replace it. When it gets to the house their is a weird half circle bent copper tubing before it enters the crawl space. What is this and can I just scrap it to make my job easier and put the shut off on a straight piece of copper coming up to a 90 degree fitting to enter the house?
Last but not least my utility shutoff isn't valve leaks a little bit as well so while I'm doing this work water still flows which makes soldering a pain. I've used white bread in the past rolled up to stop the flow. Is their anything better?
