Astralan
Have an old pull to open, twist to control shower regulator that most people can't pull.
I decided to do some research and from my findings it ends up being a Moen 1200 cartridge.
Following some youtubes and purchasing extraction tools for this model, I was pissed to find that in the attempt to "twist" the cartridge loose, it sheered off the casing tabs and pulled the stem out.
Currently, I shoved it back in and have it in place using the little horseshoe type clip, but there is nothing else.
So, browsing the posts, someone mentioned a little pricy tool: LASCO 13-2122. I can't find enough information or directions about the tool or if it will fix my problem. Seeing I've invested in both the 1225 (before I found out what was in there) and the 1200 plus the extraction tool, I'd like to see it through. I called one plumber who just gave me grief, hundreds of cartridges, wouldn't use what I got, made it a point to tell me I may need a whole new regulator and of course the beginning estimate of repairs. I see his point but it was an elaborate way to blow me off.
Can any of you experts tell me how to get the cartridge out?
One person mentioned that you can interchange the 1200 with the 1225. Is this true?
Thanks in advance. -Brian
