Those "drop in" Scrubbing Bubbles tablets are hard on the rubber seals inside your tank.
Thanks Tom. I'm not wanting to argue but the only water that is apparently coming from the tank is seeping down from under the rim of the toilet, not the chute that the flap is on. Are you aware of that? I've said it and I even added a photo of it in my last Reply of the blue lime streak buildup that the seeping creates.If water is leaking from under the flapper it goes into the bowl. Its probably why your loosing water from the tank
My house, that I bought new in 1993, has counters over 2 of the toilet tanks, so a low profile toilet is almost required to make it reasonable to work on anything in the tank.Throw those toilets in the dump and buy good toilets so that means not a kohler.
OK. Where's the seal that needs replacing? I bet I have plenty of them & I'm a 65 year old guy that's OK with tools and retired on permanent federal disability, so I've got plenty time & not enough money to pay someone to fix something simple that I can learn to do myselfThose "drop in" Scrubbing Bubbles tablets are hard on the rubber seals inside your tank.
Water does not get into the bowl unless the flapper or flush valve is leaking. Kohler are very particular about the flapper used which is why I only install factory Kohler flappers in Kohler toilets. It doesn't hurt to swap the flapper since you have so many on hand. While you have the flapper off run a finger around the lip that the flapper sits on and make sure it's smooth with no nicks or debris on it. Another test is turn off the water to the toilet and see where the water level stops. If it stops at the flapper level, it's the flapper leaking. If it stops below the flapper and empties the tank, the flush valve is leaking.Thanks Tom. I'm not wanting to argue but the only water that is apparently coming from the tank is seeping down from under the rim of the toilet, not the chute that the flap is on. Are you aware of that? I've said it and I even added a photo of it in my last Reply of the blue lime streak buildup that the seeping creates.
Best advice right here!While you have the flapper off run a finger around the lip that the flapper sits on and make sure it's smooth
I've got to say that I'm smart enough to have already known to do that months ago. I've also tried using both a new Kohler brand flap and another of my many spare new Korky flaps.Best advice right here!
LOL Sounds funny but I seriously doubt that's true. Maybe come up with a better one?The problem with our members is we really have no idea with how mechanically inclined everyone is. My neighbor designed the guided missile system for Aerojet Systems, but couldn't figure what side of the screwdriver was the handle. Just sayin'
The tank via the flapper.Guys, thanks for your continued help. Could somebody explain to me where the water comes from that runs down from under the rim when you flush the toilet on my model toilet, Koehler Low Profile K-3397?
Does it have anything to do with the water in the tank that the flap releases? It sure doesn't look to me like it does, but maybe I'm too stupid to be trying to fix this myself.
Could you please explain what you're saying? It's an incomplete statement.The tank via the flapper.
When you use the flush handle, the flapper lifts up and lets water into the bowl through the rim jets and siphon jet, then the flapper closes and the tank fills, waiting for the next flush.Could you please explain what you're saying? It's an incomplete statement.
Thanks
It was a complete statement you just didn’t understand it.Could you please explain what you're saying? It's an incomplete statement.
Thanks
Cool thanks. Now I get it. I never knew the water that the flapper lets flow did anything but rush down the molded ceramic channel into the toilet's bowl, that's why I was confused by those streaks all around under the rim.When you use the flush handle, the flapper lifts up and lets water into the bowl through the rim jets and siphon jet, then the flapper closes and the tank fills, waiting for the next flush.
When water leaks out of the tank it enters the bowl via the rim and the siphon jet. That is why you're seeing the staining around the rim.
It's exactly the same as the old Kohler one. By wiggle it, I just mean that I push down on it with my fingers and thumb around the ½" tall sticking up & sort of twist it back and forth a tiny bit.Some of the older toilets use an extra large, extra wide flapper for a solid fit. If you can wiggle it, I'm guessing it is not the needed extra large flapper.
