- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,977
Frodo,
Thanks for all the help. When I imagine what you are describing I think about a glass full to the brim with water. I put a straw in which fills with water as I put it in. Blowing on it, I think, would cause a volume of water equal to the volume in the straw to come out, and after that the air would just bubble to the surface and escape.
As that relates to blowing out the pipe: Since the ratio of volume of two pipes is the ratio of their respective radiuses squared that would work out to 0.125^2/0.375^2 = 0.111 . So if I wanted to remove the water all the way down 6 feet, I would need 6ft/0.111 = 54 ft of quarter inch tubing inside the water service line. Its hard to imagine practically.
Am I thinking about this correctly?
in essence you are correct, but you are, what i call
"brain F***ing it"
throw all the numbers you want at it, run the batteries on the calculator down
use 3 #2 pencils and a whole legal pad.
when your finished, snake 6' of 1/4'' polly pipe [ice maker tubing] down the 3/4 and blow the water out
if you have a little water left after blowing it.
suck and spit, the remainder.
practical enough ?
