robertwhite
Hi,
Please bear with me as I want to explain so you folks get the whole picture readily.
I have a double sink vanity made from a buffet/server on the 2nd floor and it does not have a P-trap, nor is there room for one.
It is plumbed into the wall which then goes to a 2" schd40 pipe which drops under the house into the crawlspace, which eventually runs out into a field drain (cow pasture), so only clean water (showers/sinks) goes into it.
It is tied into a vent above it, and also a vent before going to the field, and drainage is not an issue at all.
What is an issue, especially this time of year is that the wet mud/cow crap smell comes up thru the sink, obviously because there is no P-trap near the sink. (there is one under the house about 50 ft away before the pipe exits the foundation). The smell really is only noticeable when you first walk into the bathroom, but I would like to try an fix it
So..............If I was to put a rigid (2" w/clean out) P-trap where the pipe comes into the crawlspace, would that block the smell from going up thru the pipe?
