So had a hot water tank start to leak. Called a friends plumber who wanted 1800 to replace my 40 gal gas tank. Can't really afford that so we go in DIY mode. To take care of the main issue, the water leaking on floor, I disconnected the tank, and plugged the line. The shut off looked a little iffy, so we turned the water off at curb to do that. Then disconnected the out line and drained tank. We did this so we could have water on. Then last night we kept hearing water dripping. Found a very small but steady stream of water coming out of the out line/supply line that was disconnected from tank. Had not capped that when I took the line off the tank. Didn't know why it was coming out of a line that is disconnected from tank, but didn't want water damage, so I plugged that one too. A few hours later went to go in my utility room and found it laying in water. My front loader washing machine had water in it so full that it was coming out around the door? So my question is WHY?????????????????? Drained washer, and since the only new thing done that day was capping that out line, removed it. Now water is still coming into washer (I can see the little stream running thru where the soap dispenser is) instead of coming out of the disconnected out line on hot water tank like it was Had to turn off at curb again to get it to stop, so now no water again. Help!!
