Hi,
I would like to install a high flow water filter before the water goes into the water softener. However, our supply line is 1" copper tubing, while the water in/out are 3/4". Is there anything like compression fitting that I can use to reduce from 1" to 3/4" (without any soldering)? Is there any tools that I can use the cut the 1" tubing?
Is there any side effect from such reduction?
Thanks in advance!
Mike
Thanks in advance!
Mike
