TexasTwister
Hi everyone. This project started out to rehabilitate a flower bed into a rose garden. As I began digging, I found that the area was criss-crossed with old, unused irrigation water supply lines, and an active line. I had always had a leak somewhere and lo and behold, it was in this flower bed, coming from the active line! At this point, please look at the photo I've attached.
I've drawn white lines where the supply line used to run. Believe it or not, these two pipes were joined with a 90 degree elbow! (installed by so-called professionals) Needless to say, the stress on this elbow after 3 1/2 years was too much due to the angle involved and it gave way. I approximate this angle to be about 60 degrees.
I propose to put 45 degree fittings on the cut ends of the supply line and connect with a short 8 inch piece of 1 inch line. However that is no better than what was there before (it's still 90 degrees). I'm guessing that what I need is another fitting about half way across this span, maybe 22 1/2 degrees.
Problem is I cannot FIND a 22 1/2 degree fitting anywhere locally. Online, no one wants to sell 2 of 'em without charging $8+ for shipping. I will welcome any alternatives to my repair scenario. I thought about "flex pvc" which would work, but no one wants to sell less than 100 feet worth. I thought about maybe a piece of flexible rubber hose and a couple of clamps.
Any suggestions would be welcome! Thanks everyone.
