tb1
Hi,
Basement toilet was leaking between the toilet tank and toilet. I replaced the rubber washers on the two bolts between the toilet and porcelain water tank on the back of the toilet. Not sure sure how tight to make the connection between the tank/toilet. Snugged the connection then tightened by another half turn or so,
How tight should the connection be w/ rubber washers? Is there a different washer material than rubber?
Maybe nylon or something?
