What temp should this be
dinows
Active Member
Sep 3, 2023
26
Southern New hampshire
Standard home oil burner, 3 zones. At what temp should the burner kick off when it calls for heat. Mine is kicking off at 160
Thanks Dean
What's your differential? Does an aqua stat relay control this unit?
What kind radiators? copper fin or cast iron?
i would set the high limit to 200 f and the aquasat to 180 . you need 180 to get heat out of slant fins
Not sure if I folow you, I can only set the Aquastat high limit to one setting so please explain how I set one to 180 and the other to 200 Thank You
