Chuckiechan
I'm connecting 2" ABS to 2" ABS after I repair a section of the pipe?
I understand some will deteriorate in direct sunlight over time?
I had a roof re done, and had the pool water solar system removed and reinstalled by a solar company in Sacramento that does installs, etc.
The panels are fine, as are most of the pipes, except on one section where it keeps leaking. It's a "pipe up" and a "pipe down" right before and after the roof jacks. They have been out at least twice fixing it, and when I turned it on the other day - first time this year - it leaks like a sieve. It's ABS pipe. He says he's using the right sealant. There must be three or four individual joints leaking in this small section - unnecessary splices from their screw up's.
It's out of warranty - one year- but I'm going to see if he'll come back and fix it. But I don't have high hopes so I'll probably be hauling my 70 year old ass up there and doing it myself. It's a ~ 4 in 12 roof pitch so it's not all that bad.
I digress...
I plan to use flexible couplers, a 45, a couple of 90's, and a glue union.
My actual question:
Is there enough insert depth that using Oaty black, it will seal OK using ABS standard couplers? There is some pressure, but ABS is the standard of the solar water industry in my area.
And what flexible union do you use that can be outdoors, long term, in brutal sunlight? I know some can't be and I don't want to get the wrong ones.
BTW, even a tiny leak is unacceptable, because it will eat away my rain gutters in a year or two.
Thanks in advance...
Chuckie
The guy is going to fix it again. He says he is using 2" BLACK PVC, so there is no conflict between materials.
Neither of us have any idea why it continues to fail. Someone is doing something wrong. This is real deal business that installs solar systems. I'm out of ideas, since I assumed it was ABS.
I've Googled all over my are and can't find 2" Black PVC.
Is it really out there and I'm looking in the wrong places?
I'll try to attach a photo. You can see the white stains from the leaks - it's a salt water pool for chlorine generation.
