The big box stores (Home Depot and Lowes) both sell insulated flooring barriers, and even saw Thermafoil at my local HD. The most common seen is the Styrofoam type.
Regarding the toilet, my toilets only work correctly when I find the sweet spot on which notch to set the chain on the flush rod, and having the correct length of chain.
My surgeon is only one of a few who uses computers to align the knee correctly. At least this is what he told me yesterday. For all I know, he himself is on a knee repair forum, searching on how to properly cut off a knee and asking other members on what types of screws to use in leg surgery?
Thanks. I searched on the HD website and only got cabinets and doors in the search and Lowes had nothing on their website.
But I've found the stores often have things that don't show up on the internet.
I guess I'll have to tamper with the chain positioning more to see if I can find the sweet spot. I think I'll wait until its a bit warmer in the day bc the water is freaking cold.
I put in a load of laundry and the Electrolux machine prompted me to clean the tray. The fabric softener had clumped up and was all thick and would not leave the tray. I realized I would have to remove it to clean it properly so after examining it for a short time I saw a button that said "PUSH" so I pushed and the tray popped out. I took it and cleaned it with hot water and scrubbed it. Some of the fabric softener had dried up and hardened to be a wax-paper like consistency. That laundry area is a cold room and I think the liquid fabric softener got too cold. I poured some hot tap water into a bottle and then poured in the fabric softener (it came out in clumps at first) and then shook it up to mix it together to give a better consistency before doing the laundry.
I'm running the load again because my cats peed on some of the stuff-- I have a few cats that don't yet understand the concept of using the litterpan.
I was bummed that something caught on the pedestal drawer and I looked down and somehow our old Snoopy Icee maker had gotten in to the laundry room and it broke. I also tripped over my brother's laundry bc he's a lazy bum and just piles his laundry on the floor instead of putting it up or actually washing it.
I'm actually going to throw some of his stuff in the machine later to get it out of the way (and so the cats aren't enticed to pee on it some more).
I'm also thinking of maybe moving some boxes around in my room to make space to try
to get my linoleum ready for my bathroom, but I really need to do the self-leveling flooring first. I just hope the stuff sets up ok in cold weather. I suppose I could always turn on my dehumidifier to help.
Btw, for the toilet install, does it matter if the flange is level if I have a sufficient wax ring?
My mother said some TV show claimed you should never caulk around a toilet because if it leaks under the toilet you won't know. But my flooring guy caulked and I've seen things where people caulked around the toilet before. To caulk or not to caulk, that is the question.
I'm still debating whether I should cut a toilet sized template out of the linoleum and lay it down and put the toilet down, or if I should just cut the flange shape out and put the toilet down on top, or if I should put the toilet down and then cut the linoleum to go around it. I'm sort of leaning toward option 2 because it seems the easiest and wouldn't leave as many seams.
I'm feeling more alert today than I was yesterday.
