baalthehomeowner
Hi there!
Relatively New homeowners here, bought a home with a well. Well pump just failed a week or two ago. Guy who put in the pump said we should change the filter in about a week (said it is recommended to do so whenever a new pump is put in). We’re trying to do what seems like a simple task but everything we read online says ‘turn off water’ and then says at the well pump water Filter press the red pressure relief button on top. We did turn off water but there is no button. Just four screws on top.
so a few questions:
- by turning off the water do we just turn off the water valve by the water filter, or do we need to hit the breaker switch for the well pump to turn it off?
- if there’s no pressure relief button on the water filter, do we then have to run water after the well pump is turned off and wait until the well tank pressure is 0’d before unscrewing the casing for the water filter?
so a few questions:
