I have a 1/2 HP pump hanging on 160' of 1" PE drop pipe. Pipe broke ~6' down, but I was able to get a rope around it. I pulled with 250 lbs, but it didn't budge.
At this point, I am assuming the wires got jammed between the pump and the casing (4" PVC). But when I pull the wires at the top, I can't see any movement at the bottom. I assume it is taped well to the drop pipe. Here is the best video I was able to get of it so far:
I'm wondering how best to proceed. I could pull a bit harder, but eventually that drop pipe is going to break or separate. Would it be better for me to try pushing the pump down instead? And I could get some sort of hook to try to catch the wiring at the bottom and pull it free.
