My outside spickets are on a well. When I have the sprinkler on I get full pressure for about 10-15 minutes, then it drops to about half that. The pump will shut off for only about 5 seconds, then run again. If I turn the sprinkler off for 5 or 10 minutes and turn it back on again, I get my pressure back. The tank pressure is reading 21 psi. The instructions on the tank say it came from the manufacture with 30 psi, and also says that the tank pressure should match the pump in-line pressure, which is reading 45 psi. Is filling the tank my most likely solution? And if so, how many psi should I do? 45 psi seems high, but I really don't know what I'm doing as I'm obviously posing the question here. Thanks for any help you can give me.
