BlueAlias16
I have fixed everything on the house side, new pressure tank (set at 38psi), pressure gauge, pressure switch (40/60), checked all plumbing isn’t blocked up. I have good pressure for about 5 cycles of the pump kicking off at 60 psi and turning on at 40psi like it’s suppose to, but then all of a sudden it will kick on at 40 and then just drop to 5-15psi and stay there with only two faucets open. Seems the well isn’t pushing enough water at times but works great other times. If I let pressure build back to 60 and well shuts off it will restart the cycle again. Another 5 cycles and it looses pressure again. I can hear the well running even though it’s loosing pressure and only staying at the 5-15psi.
Any ideas? I have checked the entire house side for leaks and don’t see any. Fearing my problem is outside and down
I tried to upload videos but it won’t let me
