catfuzz
When my pump is running, the well head makes a hissing sound. Literally sounds like an air compressor is blowing air through and air chuck in there.
It is a drilled well with a submersible pump.
I replaced the pressure switch and gauge for the pressure tank.
I drained the pressure tank and checked PSI and it was 28 (on a 30/50 switch). I moved the tank around a bit when it was empty, and it did sound like there was some water in the bottom still.... but since the PSI was good, I figured blatter must be good?
I am wondering if I should go about replacing the pressure tank (i bought house 7 years ago and do not know when it was put in previously)... or if I should just call the drilling/well company to inspect the well and pump. I can replace the tank my self, so if that is a possibiltiy of solving issue, it would be a saving over having a company come inspect... but it is giving me pause spending 1k on a new tank setup, since mine is holding pressure?
Does anyone think a bad pressure tank could cause hissing at the well head? Or does this point to an issue in the well/pump?
It also seems to take a very long time to build up to pressure. I turned down the cut off to like 40, cause it just seem to keep running and running trying to get up to 50. I woke up this morning when water has not been being used... and its just running trying to get up to 40psi.... with the well blowing like a saxaphone player.
Any advice would be awesome. Long time reader of the forum and have learned a great deal... Finally registered to post.
Thanks,
Josh
Thanks,
Josh
