ad233
I am trying to replace the water valve under my sink. I am following all the dozens of videos I've seen online exactly, but the compression ring doesn't seem to compress. When I screw the valve onto the nut, even when it's from and fully threaded, the entire piece still slides right off the pipe. I have tried adding Teflon tape to the pipe and around the compression ring but nothing seems to work.
