I'm thinking he has something like this. And I used the sensor/crossover terminology wrong. And he never answered where his return line was entering his water heater.
No, I don't believe it is insulated. I have a condo built in 2020 on a slab with PEX plumbing running through it. As far as I know, there's no insulation on it. As far as a crossover valve, I'm assuming you're talking about the sensor valve that goes between the hot and cold lines under the sink to complete the recirculation loop. I don't know if this could have got plugged up somehow. I do have a water softener, but the cold water feed to the kitchen sink doesn't run through it.I'm assuming your circulating line is insulated throughout. Not that that would cause a sudden change in the way your system works, just wanted to confirm that.
If a system that has worked for three years is now not working, something broke/changed. If the thermostat that has tripped was replaced, and it is still not functioning as before, assuming the thermostat replacement is like the original, then running change Managerial Analytics process, you need to look at all the other components in the system.
Water supply = no change.
Bottom element = working, no change.
Circulating pump = working, no change.
Circulating pipe = no change.
The only component in the system that I can think of that could break or change is the sensor/crossover valve.
I'm not sure how you can check them, and $85 to replace them just to find out that is not the problem is a little steep. But maybe someone can suggest a test or a cleaning method that may resolve your issue. Just a guess using MA.
There's a timer on the pump, so I only run it during daytime hours. I don't know why it was tripping the thermostat when it hadn't been doing that for three years. Here's what I have: Hot Water Recirculating SystemsThen you don’t have a return line I’ve been speaking of.
Did you check the amp draw of the elements ? It shouldn’t have any amp draw when the thermostats are not calling for heat.
Watts divided between volts gives you amps. Check the elements for proper draw.
Does your pump run 24/7 ?
If you turn the cold water off to the heater and open a hot water faucet, does the water stop after you bleed the pressure off ?l
This is a hot water bypass system not a traditional recirculating system.
Forgive me for not trusting your description of what’s happening. You say that the heater trips out when the pump is running. Is that possible correlation without causation ? I get that all the time.
Example: lady calls up,
“ ever since you repaired my toilet my washing machine won’t spin
The pump is on a timer, so it only runs during the hours I am up. I thought I had this thing fixed after it ran a couple days after I lowered the thermostat setting, but now it's back to doing what it did. Here's the system I have: https://www.premierh2o.com/pages/500800-hot-water-br-recirculating-pump I'm beginning to think that maybe the sensor valve could be bad. This is how they work: How Do Sensor Valves Work? - Hot Water RecirculatorsThen you don’t have a return line I’ve been speaking of.
“ ever since you repaired my toilet my washing machine won’t spin “
Refer to post #26.The pump is on a timer, so it only runs during the hours I am up. I thought I had this thing fixed after it ran a couple days after I lowered the thermostat setting, but now it's back to doing what it did. Here's the system I have: https://www.premierh2o.com/pages/500800-hot-water-br-recirculating-pump I'm beginning to think that maybe the sensor valve could be bad. This is how they work: How Do Sensor Valves Work? - Hot Water Recirculators
