JGPlumbing
Hi all! This is my first time posting and I hope this is in the correct spot.
I have a 3/4 thread fitting that goes into a Pressure reducing Valve and it started leaking. I was able to take the 3/4 thread fitting out and noticed the threads were destroyed (frozen or something) on the one side. I had the copper pipe an fitting to repair that side, but i think the threads are also damaged on the coupling that goes into the Pressure Reducing Valve. I put everything back together and it stopped leaking, but not sure for how long. This is located right after the water meter.
Image with the red arrow shows where the threads were destroyed. (image is the new fitting)
Images with red circle is the part I'm trying to buy.
My question: Can i buy the coupling separate instead of buying a whole new Pressure Valve? I only get the full pressure reducer valve when I search online. Anyone know the part number or have a link to where i can buy this coupling?
3/4in thread fitting -> into Pressure reducing valve.
Thanks!
Thanks!
