Water pressure at 20psi on Utica boiler
Fred Mertz
Jan 25, 2024
NW Ind.
Water dripping for pressure relief . Pressure on gauge 20 t0 25 PSI. Should be around 12 PSI. It's 10 degrees here in NW Indiana today.
First thing to check is make sure the expansion tank is properly filled with air and has not failed. It is possible that the relief has failed but I would check expansion tank first. The hotter the water is the more pressure will be in the system.
