Mikey
We had a similar problem in a house in FL; aggressive soil ate pinhole leaks in the unprotected copper buried under the slab. Re-plumbed the entire house overhead.
I suppose it's possible for the hot to go into he cold when the cold water is used at a Hot/Cold faucet if the cold water pressure drops. But I'm not too sure it would drop lower than the hot water side.Hadn't thought of a leaking mixing valve, but the pressure from the water heater and city water on the cold side should be the same, right? So I don't get how warm water could leak into the cold water side. I also don't get how a leaky toilet could be related. Unless again, you're saying the hot side is leaking into the cold side somehow.
It's called a "plumbing crossover". Many articles about it on the Web, looks like a common problem in commercial settings. I had heard about it in residential use, but never experienced it personally.I suppose it's possible for the hot to go into he cold when the cold water is used at a Hot/Cold faucet if the cold water pressure drops. But I'm not too sure it would drop lower than the hot water side.
Still no answer on whether it may be coming out the TPR valve. It's possible Geekfather didn't know what a temperature/pressure relief valve(TPR) is.
Yes I do recall many of the commercial service sink faucets came with integral check valves. I suppose they were there for a reason.It's called a "plumbing crossover". Many articles about it on the Web, looks like a common problem in commercial settings. I had heard about it in residential use, but never experienced it personally.
O the irony... there was a discussion recently on the forum about whether or not the TPR air gap had to a) exist, and/or b) be easy to see at the water heater.[QUOTE="FishScreener, post: 103021, member: 16377
But, I’m still guessing the tpv is weeping, and outlet from the discharge the line is hidden.
Their is no alternative interpretation a T&P drain connects to the T&P with a male adaptor and the piping is run to a floor drain or floor sink with an air gap at the drain.
OR it can run out the building and drain on the ground,
it can not drain into the pan, nor tie into the pan drain,
I've dealt with many inspectors over the years, regarding plumbing and cross connections control, in many different states around the country. In one case I had to send the guy back to his boss, he was so far off in his ideas.@Diehard: I think you believe correctly. The neat thing about most codes is there is always an alternative interpretation. The only interpretation that always works is "when in doubt, ask your AHJ." I'll bet, however, that you could find AHJs around the country who would agree with Frodo, or me, or both, or neither.
Don't know if it's code or not, but it doesn't make much sense, unless there's provision for making sure the "hot water" is in fact hot at the time of use.I have seen a few furnace humidifiers plumbed to hot water.
