rajsingh
Hi All,
I recently noticed the shower pressure wasn't very high. I thought I may have to readjust the pressure switch. But when I attached a water pressure gauge on the outside water spigot, the psi never went above 30. Generally I have it set around 30 psi cut in and 50 psi cut off. I then went to the well pump PVC pipe and heard sounds of water falling into the well and the motor continually running. I turned off the motor and I continued to hear what sounded like water falling into the well and this sound continued until the water pressure gauge went down to 0. When I turned the motor back on, the sound started again.
The pitless adapter is 3 feet 9 inches below the top of the PVC pipe. I used a endoscope camera and sent it down there to see if there was a leak and I didn't see anything. I then attached napkins to a thin rod and sent it into the well about 8 feet below and when I pulled it out, the napkins were dry. I would've never imagined a pipe leak below 8 feet into the well. We built a tool 2 years ago to unscrew the flipper holding the adapter about 3 feet 9 inches into the well, we built it to pull out my uncle's well pump, so I'm glad I have that and I'll be pulling it out this weekend with their help to see what's the issue. But I wanted to ask here, if anyone can think of how that leak could have happened or where this leak could be?
Thanks
Thanks
